2003 Chrysler Town and country.van 3.8 auto cooling fan relay switch
Yes I found out that the check engine light could not be reset when the errorcode comes up P 0400 or something and when you Google it it says it's the engine cooling fans . You can check the fans with wires from battery. Simple fix is pop open hood take 6 Philips screws out of grill top remove grill about 5 minutes then reach inn with sheetrock screw use a drill and drill out aluminum rivet disconnect connector put 60 dollar replacement relay in same place use a screw to secure it it is inside behind grill on drivers side front of radiator ...then you have to disconnect battery cables reset computer and you should be good
woodhog
Sep 30, 2022 11:21 AM
kjs
Aug 15, 2018 11:02 PM
