2009 T&C 3.3 Ambient Temperature Sensor
Old Jul 7, 2016 | 04:28 PM
kandre's Avatar
Default 2009 T&C 3.3 Ambient Temperature Sensor
Does anyone know where can I find the steps or directions for installing the Ambient Temperature Sensor? Diagnosis Code Came up that it needed to be changed. We replaced the Air Intake Sensor but that wasn't what needed to be changed. Also could that cause the coolant to run out Daily? No leaks found. Thank you!
Old Jul 7, 2016 | 08:25 PM
Ambient Temperature is outside air temp how hot it is outside the sensor is in teh vary front look between the grill area.
Old Jul 8, 2016 | 07:57 AM
kandre's Avatar
Okay Thank you! I found it. It's about 98 degrees daily I li e in south Florida
Old Jul 8, 2016 | 02:51 PM
Coolant runs out daily with no leaks?
1. Look harder for a leak. There's a leak somewhere.
2. Check for an internal leak in the engine. Look for oil in the crankcase (motor oil looks like chocolate milk) or a blown head gasket.
gr00vyd0
14
Aug 29, 2020 01:53 AM
Dan Malone
Apr 26, 2020 09:25 AM
wildebeast
Feb 29, 2016 11:45 PM
johnchrisr
Oct 10, 2014 01:19 PM
robwill
Mar 15, 2011 03:50 PM
