Crankshaft position sensor
Old Nov 9, 2010 | 07:49 PM
BACdaG1's Avatar
Default Crankshaft position sensor
Where is the crankshaft position sensor on a 2002 PT Cruiser Limited?
Old Nov 9, 2010 | 07:50 PM
BACdaG1's Avatar
thank you
Old Nov 9, 2010 | 07:51 PM
BACdaG1's Avatar
Thank you for your help
Old Nov 10, 2010 | 09:35 AM
The crankshaft position sensor mounts to the engine block below the generator, just above the oil filter (Crankshaft Position Sensor—2.4L).
Remove the air cleaner lid, disconnect the inlet air temperature sensor and makeup air hose.
Remove the negative battery cable.
Raise the vehicle and support.
Disconnect electrical connector from crankshaft position sensor.
Remove sensor mounting screw. Remove sensor.
James Scarlott
Sep 21, 2012 11:29 PM
nelpasa
Jul 9, 2012 02:52 PM
Gypsy
Jun 29, 2011 01:50 PM
96RedLXI
Jul 19, 2008 08:38 AM
