Electrical Problem w 2000 Sebring
Old Nov 13, 2008 | 01:12 PM
leoodonnell's Avatar
Default Electrical Problem w 2000 Sebring
experiencing intermittent problems w/ fuel gauge. Been told that it might be a sensor in the fuel pump and cost around $700 to replace. Is this a common problem? Is there a problem if I continue to drive vehicle?
Old Nov 13, 2008 | 09:30 PM
dodgetech1's Avatar
Default RE: Electrical Problem w 2000 Sebring
most likely it is the gauge on the sending unit causing the problem. To replace this you need to replace the whole fuel pump module. As long as you know how much gas is in your vehicle and keep track of it you should be okay. Other wise you'll be walking to the gas station.
Old Nov 14, 2008 | 03:42 PM
You didn't say whether your Sebring was a coupe or convertible. If it's a coupe, it's an easier replacement. If a convertible, it requires dropping the fuel tank out.
For $700, I think I'd make it a point to fill up every couple hundred miles.
bamabeauty81
Mar 19, 2012 06:10 PM
bamabeauty81
Jan 6, 2012 05:13 PM
Beware_of_Dog
May 26, 2010 06:18 AM
JeremyH82
Feb 8, 2009 10:51 PM
b0bathm
Jul 24, 2008 10:41 AM
