overheated voyager
Old Mar 26, 2010 | 11:55 PM
backsthepack@cox.net's Avatar
Default overheated voyager
I have 2003 Chrysler Voyager and two days ago it overheated on me. I changed the thermostat today and when I was filling it back up with coolant I noticed it was leaking form the side of the head between cylinders 1 and 3 behind the exhaust manifold. Best I can tell it looks like it has a pinhole in the side of the head. Does this mean that I cracked the head? If so should I replace both heads just to be safe? Thanks for the help.
Old Mar 27, 2010 | 06:50 PM
The crack in the head could have been the cause of the overheating or the result of it. If it cracked and you lost coolant, that could result in overheating, or like you said, if it overheated (badly) for another reason, a cracked head might result.
Either way, that's a problem that needs to be dealt with. Should you replace both heads? Hard to say. You could consider putting some epoxy on the known leak to temporarily seal it up long enough to run a pressure test. If the system holds pressure you could take your chances and just fix that one side. Remember, you might have a leak somewhere else and that other leak could have caused the coolant loss which resulted in the overheating, and the cracked head could have resulted from that.
The problem is, it's a big teardown to pull one head, and not much labor increment to keep going and do the other side at the same time.
Tough call.
tom66
Dec 31, 2013 04:58 PM
LadyRossi
Jan 1, 2012 04:25 AM
cowli4nia1
Sep 6, 2011 11:17 PM
BernieCostello
Apr 6, 2011 03:25 PM
rjdavis61
Sep 26, 2010 06:53 PM
