P0138 & P2097 codes on T&C
will what I know through my experince is that a code of the o2 sensor will convert to 2097 if the problem have been running for a long time or if both of the readings before and after the cat are the same so if you have cleared the cat or you have the code for long time it might be the cause
- P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
- P2097 or P2099 Post Catalyst Fuel Trim System High Limit
dolemite44149
Jul 16, 2013 02:12 PM
