P0138 & P2097 codes on T&C
Old Apr 14, 2010 | 04:22 PM
huffmancowboy's Avatar
Default P0138 & P2097 codes on T&C
The P0138 is an 02-sensor circuit code. The P2097 is a post catalyst fuel code - trim system too rich. Could the O2 sensor be causing the P2097 code? Any other suggestions?
Old Apr 14, 2010 | 04:58 PM
huasi87's Avatar
will what I know through my experince is that a code of the o2 sensor will convert to 2097 if the problem have been running for a long time or if both of the readings before and after the cat are the same so if you have cleared the cat or you have the code for long time it might be the cause
  • P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
    • P2097 or P2099 Post Catalyst Fuel Trim System High Limit
    so it seams that you have a sensore problem since both of them at the same side
    Jfizzle
    Feb 22, 2020 04:37 PM
    dolemite44149
    Jul 16, 2013 02:12 PM
    SpudlerT+CTouring
    Dec 13, 2011 12:20 PM
    otto
    Nov 10, 2010 10:02 AM
    paulg_ca
    Jun 22, 2007 08:39 PM
