02 sebring ect,pcm and cooling fans
Old Aug 26, 2011 | 11:28 PM
Dakota_don's Avatar
Default 02 sebring ect,pcm and cooling fans
got a 02 sebring with a 2.7.. cooling fans arent kicking on..
I replaced the water neck housing cause it was leaking.. it had the new ect installed in the housing ( cooling fans didnt work before) anyway if i disconect the ect, the fans kick on after a short delay.. if i hook the ect back up they will kick off after a delay.. I didnt find any fuses or broken wires.. I tried looking online for a diagram but no luck. I think its either wiring or the pcm. Oh almost forgot the dash temp gauge doesnt work either..nor do the dash lights.. I beleive the ect sends a signal to the pcm, which then send a signal to the cooling fan realys to turn the fans on, also at the same time the pcm sends a signal to the dash gauge so the driver can monitor the engine temp.. Plus the pcm uses the ect data to comand other operations like air fuel mixture at cold starts and idle..
anyone have a test proceedures?
thanks
gonepostal
Mar 12, 2014 01:29 AM
tmcglaughlin317
Mar 11, 2014 05:32 AM
brieanna82
Jun 8, 2012 12:28 AM
Dakota_don
Aug 27, 2011 03:18 PM
SPINNAKR
Dec 6, 2007 02:50 PM
