06 Town and country AC problem/recalibration?
Old May 24, 2011 | 05:36 PM
rizwan1377's Avatar
Exclamation 06 Town and country AC problem/recalibration?
I have a 2006 T&C. It has a dual climate control, the driver side blows warm air (55F) and the passenger side blows cold air about 45(F) degrees. I have changed the control head board, receiver drier, expansion valve, temperature door control motor. I tried to recharge the freon twice with proper amount. But still it has the same problem. You can email me any solutions/opinions at rizwan_1377@live.com. THANKs in advance.
Old May 24, 2011 | 05:58 PM
Djinn-n-Tonic's Avatar
You have a broken Blend door. ....
Who put the control motor in???? This should have been seen during install.
Old May 25, 2011 | 02:15 PM
rizwan1377's Avatar
Thanks for replying.
No, the blend door is fine, I am in the middle of changing the evaporative core(evaporator). I will let you the know the results.
Old May 25, 2011 | 05:57 PM
rizwan1377's Avatar
okay, so the evoporator didn't help wither, Still the same problem. What else could be wrong?
Old May 25, 2011 | 07:07 PM
Ok ,....
Answer a few questions for us....
Does this van have rear A/C?
How much freon did you put in, and was the system evacuated prior to charging?
There are two blend doors, side by side in the heater housing. are the pivots intact?..Did you look at the recirc door when you split the casing? Does the air Discharge from the proper vents when you change positions?
Chrysler Forum Editor
May 29, 2014 03:38 PM
GPrescott
Jan 7, 2014 10:56 AM
jeffracine
Nov 5, 2012 10:08 PM
mrscaborobo
Apr 30, 2009 09:34 AM
300winchester
Mar 29, 2009 02:48 PM
