07' 3.5 300 coolant leak
Old Jan 2, 2020 | 02:39 PM
C.Marble's Avatar
Default 07' 3.5 300 coolant leak
07' 3.5 300 leaking coolant behind belt casing, im not sure if its the water pump seal or if it could be something else, also im not 100% about if i change the pump do i have to change the timing belt as well? Plz help thank you
Old Jan 2, 2020 | 02:48 PM
I would replace the timing belt and water pump yes
Old Jan 3, 2020 | 01:40 PM
C.Marble's Avatar
Do you know the reason the timing belt has to be replaced even if it looks ok, and does the timing belt tensioner NEED to be replaced, or can you use the existing one?
Old Jan 3, 2020 | 07:32 PM
required replacement at 100k you can do what ever you want its your car.
HemiMoparGuy1981
Jun 10, 2019 07:25 PM
ttype
Feb 8, 2017 09:08 AM
Apr 3, 2012 02:50 AM
jam3700
Dec 1, 2011 02:53 PM
binky42
Cirrus & Breeze
Jul 20, 2011 06:10 PM
