2.7 engine swap issues
Old Oct 28, 2009 | 03:42 PM
ksorce's Avatar
Default 2.7 engine swap issues
I have a 2007 Sebring with the 2.7 V6. I needed to chaneg the engine and found a 2009 2.7 V6 from an Avenger. The intake manifold is slightly different. There appears to be some sensor or servo device on the 2007 manifold and wiring harness that is not on the 2009. What is this and is it necessary? If I want to use the 2009 manifold, will there be a problem if this other wire is not plugged in or can I block it off some how? Thanks
Old Oct 30, 2009 | 08:11 AM
22chrysler's Avatar
the motor will fit fine but you need to use all the parts that match the car like manifolds wiring etc.
thook
Jan 20, 2024 01:28 PM
Massive_Dynamic
Sep 19, 2014 05:04 AM
sebringphanatic
Jul 25, 2009 12:03 AM
andbudzi
Feb 20, 2008 04:07 PM
GreenCar
Jan 12, 2006 03:00 PM
