2000 concord blows warm
Old Apr 25, 2011 | 07:51 AM
project260's Avatar
Default 2000 concord blows warm
I have a lxi concord which blows the same temp (hot) even when i turn the dial to lo 60 degrees, on the heat mode and even on the ac mode.. The compressor is kicking on but still blows the same temp about 112 degrees.. The one ac line is cold and the other side is hot.. My wifes sister gave me the car and they had the evap replaced along with the climate controls assembly, but that was a used unit..They said it did work but that was in December and they never tried it after that.. I was thinking it could be that used control panel in the dash or the a/c blend door actuator.. Like i said even in heat mode the temp won't change when i turn the dial from 90 degrees to 60 degrees, then i turn a/c on and no real change in temp, maybe 4 gegrees but the compressor is on.. thank you for any reply!!!
Old Apr 25, 2011 | 08:27 AM
project260's Avatar
My bad this may be the wrong forum, re posted in the past models section.sorry for that!!
project260
Apr 5, 2014 06:33 PM
balasubas
Dec 17, 2010 08:52 PM
CML
Jun 20, 2010 04:30 AM
Mr Goodwrench
Jun 10, 2009 07:05 PM
v1rott
Dec 20, 2006 02:27 AM
