2000 PT Cruiser power steering removal
Old Apr 22, 2013 | 09:17 AM
sluglet's Avatar
Default 2000 PT Cruiser power steering removal
hi everyone. need a bit of help.
I'm from the UK so the cruiser is right hand drive, 2000 model, 2.0litre.
Basically the power steering failed whilst driving. The belt hadn't snapped but had come off the pulleys due to the tensioner/idler pulley seizing up.
Now i need to remove this plate/assembly. The assembly is mounted on a plate thats bolted to the bottom end. subframe bolts removed and engine mounts removed that side so i thought i could drop the engine one side and it would come out.
all the bolts holding the assembly to the engine are removed but there is no space at all get it out. with the subframe bolts removed etc the engine does drop but not enough.
does the engine need to come out? the only other thing that might help is if i remove the cambelt cover. check out the pics, a bit of guidance would be great.
[IMG][/IMG]
Old Apr 22, 2013 | 09:18 AM
sluglet's Avatar
[IMG][/IMG]
Old Apr 22, 2013 | 09:20 AM
sluglet's Avatar
[IMG][/IMG]
Old Apr 22, 2013 | 12:22 PM
u take it out from the front
Victor L
Jan 12, 2014 08:38 AM
Husker
May 12, 2012 08:11 AM
moriamoria
Mar 22, 2012 10:55 AM
tbird2340
Aug 9, 2011 09:57 PM
05ionredline
Jan 11, 2010 09:24 PM
