2001 PT, flahers, turn signals or headlights?
Old Nov 7, 2010 | 08:38 AM
xenon's Avatar
Default 2001 PT, flahers, turn signals or headlights?
blown fuses for both headlight switch and flahsers. replaced, they blew , unpluggged harness from turn signal headlight switch assembly, harness appears to be swollen and charred, am about to pull switch and look at it, but not sure how to check it only know how to replace it. any clues, hae you seen this happend often,
thanks
Old Nov 7, 2010 | 11:29 AM
TNtech's Avatar
Never seen the pigtail at the Multi switch do that. Obviously it happened. Almost all of the repairs I do are at that medium size white connector down by your left shin. Usually it's an ignition switch supply wire.
Old Nov 7, 2010 | 06:22 PM
xenon's Avatar
I have taken the multi switch out, looks OK, but not sure how to test, could it have a short in it?
with the switch unplugged, fuses do not blow, only when the switch is connected to the harness?
Old Nov 8, 2010 | 12:54 PM
TNtech's Avatar
If you can splice wires, the dealer should be able to order you a repair pigtail kit for that. No way I would put that multi switch back in. Get a new one and a new pigtail kit. Important DO NOT forget to check the connectors down uder the drivers side for damage also.
Old Nov 9, 2010 | 06:24 AM
xenon's Avatar
The PT is parked for now, replacement switch, junk yard $55, dealer $165, Advance Auto $41, new switch on the way, we will see what happens
Old Nov 9, 2010 | 08:52 PM
xenon's Avatar
OK, I am at a loss, replaced switch, repaired wire. still no flahers or turn signals. headlilghts OK on low, but blow fuse when put them on high?
We had the tranny replaced about a month ago. have drove with no problems. is it possible that part of the harness is kinked or has rubbed into something. not sure where the harness is located. or a spot where it could have a short.
not sure what my next step should be...
may go back to the trans shop and at least see if he will put it up on th rack and have a look see.
can I unplug all the lights, then check the harness for a short.
tired of blowing fuses every time I plug something in. is there a min resettable fuse, kinda like a breaker.
TAvsGN
Nov 6, 2012 09:49 PM
rayboy55
Jun 29, 2010 05:08 PM
Ayce
May 18, 2009 08:44 AM
csigurd
Jun 25, 2008 08:12 PM
evo8rcr
Jun 4, 2007 07:17 PM
