2003 Ram Pickup constant hot wire
Old Oct 17, 2007 | 06:01 PM
ClwChris's Avatar
Default 2003 Ram Pickup constant hot wire
I grounded out a constant how wire while installing a new radio. I looked at the fuses under the hood and they were all fine. Not only does my radio not work but my lights wireles remote door locks does not work unless I have the key in the on position or while the truck is running. Is there a fuse I am not aware of or should I be looking elsewhere?
Old Oct 17, 2007 | 07:43 PM
truck tech's Avatar
Default RE: 2003 Ram Pickup constant hot wire
Hello,I am not a chrysler tech. I am having troubles with my own 05 van, but is there a fuse under the hood thatis labeled IOD? If there is remove it for a few secondsand then put it back in . This reset the bcm and may slove the problem. I am not a expertbut try it. Hope it helps.
Old Oct 18, 2007 | 09:45 AM
moe's Avatar
moe
hi chris.look in under hood fuse center cavity #51 should have single or double fuse.truck tech was right on the money!! let me know moe.
Chrysler Forum Editor
May 7, 2014 10:48 AM
Nov 9, 2013 05:08 PM
Pinefang
Mar 14, 2012 02:03 PM
May 14, 2008 08:55 PM
DodgeInfoCenter
Jan 16, 2006 04:51 PM
