2007 Chrysler Aspen
Old Mar 29, 2016 | 09:21 PM
beast39's Avatar
Default 2007 Chrysler Aspen
2007 Chrysler Aspen 4.7 147k miles with trouble code PO443. What is the most common trouble to cause this code? What should I check and where is it located in this engine? Thanks in advance for any and all help. Would it cause more damage if I drive it 1-2 days?
Old Mar 30, 2016 | 08:00 AM
ChryslerCares's Avatar
P0443-EVAP PURGE SOLENOID CIRCUIT
When Monitored:
The ignition on or engine running. Battery voltage greater than 10 volts.
Set Condition:
The PCM will set a trouble code if the actual state of the solenoid does not match the intended state. One Trip Fault. Three good trips to turn off the MIL.
POSSIBLE CAUSES:
(K52) EVAP PURGE CONTROL CIRCUIT SHORTED TO VOLTAGE
(K70) EVAP PURGE SOLENOID SIGNAL CIRCUIT SHORTED TO VOLTAGE
(K52) EVAP PURGE SOLENOID CONTROL CIRCUIT SHORTED TO GROUND
EXCESSIVE RESISTANCE IN THE (K52) EVAP PURGE CONTROL CIRCUIT
EXCESSIVE RESISTANCE IN THE (K70) EVAP PURGE SOLENOID SIGNAL CIRCUIT
EVAP PURGE SOLENOID
POWERTRAIN CONTROL MODULE (PCM)
Old Mar 30, 2016 | 08:36 AM
beast39's Avatar
Thank you so much for your reply. I failed to say that the fault code said at the end "C fault", in case it makes a difference. Also the battery light has been coming on intermittently. Would this be associated with this problem? Would you have engine diagram to locate these parts on engine and procedure to do the Checking? The battery and alternator have been checked by Autozone and found to be ok. Grateful for the help, thank you.
Old Mar 31, 2016 | 09:19 AM
beast39's Avatar
I have erased code PO443 and have driven car about 50-60 miles and code has not come on. Hopefully it will not. However, still have battery light coming on. Alternator and battery have checked out ok. How would I check for faulty battery light?
Old Apr 3, 2016 | 06:56 AM
beast39's Avatar
Well the problems are back, PO 443 and battery light coming on. Had battery checked again and found to be bad. Now new battery but battery light still comes on. Will try checking procedure on purge valve. Could these be one problem? Thanks
Old Apr 28, 2016 | 05:47 AM
beast39's Avatar
The evap purge valve and alternator were replaced. Vehicle runs good now without any MILs. Vehicle now seems to stop cooling when vehicle is at stop. Please help.
Old Apr 28, 2016 | 11:19 AM
Hi beast39—we’re not trained technicians, so unfortunately I can’t provide you with any technical advice at this point. I would recommend trying the FCA dealer in your area for service, or asking them for advice if you prefer DIY.
Kori
Chrysler Social Care Specialist
Aug 8, 2017 07:16 AM
jimhild
Nov 17, 2010 09:00 AM
PEDROCCOTA
Apr 8, 2010 10:22 AM
vickicorinne
Jan 27, 2010 11:58 AM
torres
Apr 2, 2007 11:56 PM
