92 Ram Cummins diesel battery problem
Old Mar 10, 2018 | 02:34 PM
harrym's Avatar
Default 92 Ram Cummins diesel battery problem
I don't drive my RAM diesel pickup very often, so I want a battery charger to get it started at times. What would be a good charger? This is a single battery 3/4 ton pickup.
Old Mar 11, 2018 | 03:47 PM
You'll need a massive amount of current to get that thing started, hundreds of amps. Few chargers are capable of that kind of amperage, and cost a lot. You could consider keeping the vehicle battery in the garage and on a trickle charger, installing the battery each time you want to use the truck. If that's too much of a PITA, you could consider keeping another battery on a trickle charger, and wheeling it out to jump start the truck. There are trickle chargers that you could wire to the truck, if you have a suitable outlet that's protected from the weather at a reasonable distance from the truck.
If you know in advance when you are going to need the truck, an overnight charge with about a 6 amp charger should be enough to get it started. A battery that is left to run down to dead frequently and then charged up will be pretty well shot fairly quickly. Lead-acid batteries last much longer if kept charged.
harrym
Aug 31, 2016 04:04 PM
RacingJunk
Jun 24, 2015 05:47 AM
RacingJunk
Jun 24, 2015 05:08 AM
Leedsman
Jun 17, 2015 03:30 PM
empee
63
Nov 5, 2011 04:00 PM
