98 Sebring, Cranks but woltn fire.
Old Nov 29, 2009 | 04:10 PM
98LXI's Avatar
Default 98 Sebring, Cranks but woltn fire.
Hi, i have a 98 Sebring Lxi, It has 145k on the chassis body, with 80k on its second motor. It will crank over, and over but will not fire. I have tried to start it with starting fluid and it pops and kicks so i beleave its geting spark. When i turn the key to the on position the fuel pump kicks on for 2 seconds and cuts off however does not run when cranking the motor. I have checked the asd relay and im having the same prob, even with a new relay. At a loss i borrowed a obd2 scanner and my computer isnt kicking any codes, I heard that a dead computer will respond the same. What should i check next? im starting to think its happy honda days time, but id like to get this chrisler/mitsu running, even if just to sell it.
Any help will be greatly apriceated, Thanks
Old Nov 29, 2009 | 07:10 PM
dont think u have spark go make sure 100% as for the asd and fuel pump they are working correctly they dont need to be on unless the engine is running so they do shut off after 2 seconds.
Old Nov 29, 2009 | 08:21 PM
98LXI's Avatar
So, lets say im not geting spark. I would begin to suspect the crank position sensor, right? Is that inside the distributor or under the distributor closer to the bellhousing?
Thanks for the quick help.
Old Nov 30, 2009 | 02:21 AM
leeb's Avatar
That's where I had to go... relatively inexpensive too.
(UNDER the distributor, #10 bolt and slides in right-to-left into the bellhousing)
Old Dec 7, 2009 | 11:54 AM
98LXI's Avatar
so, i replaced the cps and it ran, yay! but i say ran because it now dosnt run. it ran flawlessly for 5 days, then just like before i went out sunday morning and it cranks but....
what could be fouling my crank sensor? is there anything aside from the cps i should suspect?
thanks agn for the help
Gonzo-
Sep 28, 2012 04:58 AM
DAG
Feb 12, 2012 10:51 AM
size2020
Oct 17, 2009 08:21 PM
Greg
Jul 30, 2009 09:34 AM
jonboy_4x
Apr 6, 2008 12:19 AM
