Auto headlights
Old Oct 3, 2007 | 08:11 PM
redpac's Avatar
Default Auto headlights
On my Aspen I replaced the OEM nav system with a Pioneer. I lost the function of the auto headlights, I think they use the same sensor as the GPS, it had 4 wires on the plug, which was right in the middle of the dash, any suggestions would be appreciated, or something I could try, thanks
Old Oct 3, 2007 | 11:37 PM
Default RE: Auto headlights
the auto part is a mux return to the cluster. Has nothing to do with the radio. U should take it to the dealer to see if u by chnage shorted out the front controler when u were messing with the new radio.
Old Oct 4, 2007 | 02:10 AM
Gold Cruiser's Avatar
Have you checked any of the fuses?
Old Oct 9, 2007 | 01:51 PM
redpac's Avatar
Check fuses all ok, hooked up old radio everything works fine again, so it has to be something else, where does the auto H/L sensor at?
Old Oct 9, 2007 | 11:45 PM
You may want to try checking out this link. It may be of some help to you, not sure? Worth a look anyway: http://www.lxforums.com/board/showthread.php?t=16999 If it does not help you. I would do what the Tech suggested. Good luck!
Old Oct 10, 2007 | 01:30 PM
redpac's Avatar
Thanks, but I already have the auto H/L, but my wife's Magnum doesn't so I will try that with hers.
Old Oct 11, 2007 | 02:25 AM
This link may help a little. Worth looking at anyway. Good luck!
http://www.wjjeeps.com/lamps/headlamps.htm#SENSOR
Old Oct 19, 2007 | 06:45 PM
redpac's Avatar
I'm sure why, but after I disconnected, and reconnected my battery the auto H/L's work just fine now, thanks for everyone's help
Otis857
Feb 7, 2011 08:44 PM
JSchneid
Oct 11, 2008 09:31 AM
acmectec2001
Apr 12, 2006 02:28 PM
mick1000s
Dec 2, 2005 08:20 PM
Mcex
Oct 18, 2005 04:43 AM
