brake issues
Old Jul 25, 2023 | 07:25 PM
citypark007's Avatar
Default brake issues
I had a left front speed sensor.. no signal and left front brake sticking issue...replaced sensor and new caliper & rotor.... same issues(sensor cable read good on ohms and 12v from harness) also replaced abs module...pulling hairs advice needed..what am I missing. dont say booster it still stops on a dime and gives you change!!
Old Jul 26, 2023 | 06:58 AM
ggoose's Avatar
First the basics - year make/model and mileage please
With most Chryslers, the abs tone ring (toothed metal strip) is part of the wheel hub bearing. You will need to verify the tone ring is intact.
You note the front brake is sticking which I believe is a separate issue from the no signal. At times the flexible rubber brake hose will collapse internally and not allow the caliper to fully release.
Old Jul 26, 2023 | 08:29 AM
2005 Chrysler T & C Touring 95K miles...will try changing rubber line
Mike Tucker
Aug 5, 2019 01:42 PM
mharmon777
Apr 10, 2012 10:54 PM
yaxo11
Cirrus & Breeze
May 5, 2010 10:23 PM
jquinones
9
Mar 29, 2008 07:50 AM
3.3lxbluevan
Nov 21, 2007 11:38 AM
