cant remove bolt from rack and pinion
Old Oct 9, 2007 | 10:59 AM
playboy00786's Avatar
Default cant remove bolt from rack and pinion
99 lhs....trying to remove my inner tie rod from the rack and pinion and i cant seem to budge it loose....i have trie everything heating it up...sprayed penetrating oil on it....its not rusted...the area is only big enough to barely fit a socket wrenhin the area...any ideas on how to get it loose....do i need a special tool or anything?
[align=left] [/align]
Old Oct 9, 2007 | 12:14 PM
Gold Cruiser's Avatar
Default RE: cant remove bolt from rack and pinion
Are you turning it in the correct direction? I believe some have left hand thread. Good luck!
Old Oct 9, 2007 | 01:36 PM
I will try that...thx...any other ideas?
Old Oct 9, 2007 | 02:33 PM
still cant get the dang thing to budge...really need some ideas!!!
Old Oct 9, 2007 | 11:20 PM
You may want to check out this link: http://images.google.com/imgres?imgu...%3Den%26sa%3DG I would also consider getting a repair manual so you can see how the inner tie rod is suppose to be removed. Sorry, I could not be of more help. Good Luck!
Old Oct 12, 2007 | 06:02 PM
moe's Avatar
moe
had that problem in the past alot! might need to replace tie rod end as well! is bushing worn on center bushings? they can be replaced by themselves.dealer sells just bushings,but the install tool is hard to find.
george3405
Feb 12, 2017 12:20 AM
Tutts.inc
Sep 19, 2013 10:17 AM
gtp6515
Feb 11, 2012 10:07 AM
Huggy59
Oct 18, 2011 02:33 AM
ejm
Nov 29, 2005 01:31 PM
