Car Wont Start
Chrysler pacifica 2008 4.0 awd Sig. Series
If it is a hot day outside and my windows are
closed my car doesn't want to start...I have to then open the windows and wait between 45 min to 1 hr 25 min and then the car will start.
If the windows are opened already the car will start.
All the lights and power work in the car. I have already changed the battery and the ignition and also the starter
twice. Is there some type of sensor or ignition relay
inside the car preventing it from starting when the
inside gets too hot with the windows closed...my
mechanic doesn't know what to do anymore
please help!!!
please help!!!
No codes are coming up for 2008 pacifica
I am thinking about replacing the tipm...
Are there any fuse boxes inside the car because I can't find any. That seems like a logical explanation since something inside the car is getting too hot with the windows closed not letting the car start
My mechanic uses the standard scanner and no errors are coming up...
Well I had an extra ground wire put on my battery yesterday I was hopefull that this will solve my problem...
Today I left my house at 1130am to go to home Depot and the car started right up...I was amazed because the car was sitting in the sun for a few hours now with the windows closed...
So I'm in home depot for almost an hour...get in the car to leave but it doesn't start...all the power works as usual but it just wont start...every ten minutes I would try to start it again and finally right before I was going to call a tow truck it started....1 HOUR 10 MINUTES LATER
I guess the extra ground didn't help...does anyone have any more suggestions???
Someone also told me it might have something to do with the ANTI- THEFT RECEIVER??
Thankyou anyone for you time and input
Well today my mechanic replaced the ignition housing...He showed me the bad part and there was a Crack in it that he said probably wasn't making a proper connection...I hope this works I will test it out the next few days
ekhealy
May 23, 2011 10:47 PM
peterjv
Apr 21, 2011 12:45 PM
