Cheap tool to loosen radiator petcock
Old Nov 24, 2009 | 07:19 PM
Termite's Avatar
Default Cheap tool to loosen radiator petcock
A couple of week ago I was replacing the coolant in a 2004 Sebring sedan. I noticed that the radiator petcock was in reach of my left hand, but I couldn't get my fingers in the right position to loosen it. I saw where some people said to remove the lower radiator hose to get the coolant out, but it sits about 6 inches from the bottom, and I wanted to be able to remove as much coolant or water, so I could be sure to get in enough antifreeze to mix with the existng water left in the engine after flushing for a strong enough mixture for freeze protection.
I came up with a tool made from an old vitamin bottle lid with a slot cut into it to fit the handle of the petcock. It is a little under 2.25 " in diameter with a slot @ 1 and 1/8" long by 3/16th's wide.
When you fit it over the petcock, it is easy for your hand to grab it, and the larger size gives you more leverage to twist it open.
I heard some people say sometimes the petcock gets stuck, but in my case it worked out great.
Attached Thumbnails Cheap tool to loosen radiator petcock-petcock-tool.jpg   Cheap tool to loosen radiator petcock-petcock.jpg
Old Mar 27, 2010 | 01:06 PM
wolong's Avatar
Default Petcock tool
When I try to view your photos I get a vBulletin telling me that I do not have the privilege to view them.
Old Mar 27, 2010 | 06:53 PM
Cool tool. Nice job, Termite!
Old Sep 4, 2011 | 10:19 AM
Ironcheese's Avatar
Can we replace a leaking radiator petcock on 2004 sebring? Sure would beat having to replace the radiator like 2 shops have offered. LOL
Old Sep 4, 2011 | 01:52 PM
TNtech's Avatar
Is it leaking? Will it not stay in? I have a fix for that if it is popping out.
chrysler2001
Dec 30, 2014 11:48 PM
yelram
Jul 15, 2014 06:49 AM
Scotsman4th
Mar 25, 2011 02:50 PM
illumitech
Nov 22, 2010 05:56 AM
bumu
Feb 18, 2007 01:44 PM
