CHECK ENGINE LIGHT
Old Nov 7, 2006 | 11:51 PM
flogirl_1752@yahoo.c's Avatar
Default CHECK ENGINE LIGHT
hI,
i'M HAVING A REAL PROBLEM. I PURCHJASED A 1992 CHRYSLER LA BARON. I STILL HAVE TO PUT IT IN MY NAME @ THE D.M.V. I TOOK IT TO THE SMOG GUT. HE SAID EVERYTHING CHECKED OUT PERFECT EXCEPT THAT THE CHECK ENGINE LIGHT ON THE DASH IS ALWAYS ON. THERE IS NOTHING WRONG WITH MY ENGINE . IT HAS NO LEAKS AND IT RUNS FINE. WHAT I WOULD LIKE TO KNOW IS WHERE IS THE RESET SWITCH FOR THIS LITTLE TROUBLEMAKER LOCATED.tHE LIGHT STAYED ON AFTER THE TRANSMISSION OIL WAS CHANGED.
HELPPPPPPPP!!!!!!!!
Old Dec 7, 2006 | 07:02 PM
Default RE: CHECK ENGINE LIGHT
YOU WILL HAFT TO HAVE SOME ONE HOOK UP A DRB2 TO IT AND SEE WHAT IS MAKING IT COME ON. THE GUY MORETHEN LIKELY USED AN AFTERMARKET SCANNER AND IT WONT TELL U EVERYTHING THAT IS REQUIRED
qbasicer
Sep 25, 2012 02:58 PM
RobinVA
Jan 5, 2010 10:18 PM
cacarrollsr
Cirrus & Breeze
Nov 11, 2006 10:47 PM
teresadogg
Nov 2, 2005 03:21 PM
ChryslerNamedTrixie
Oct 20, 2005 03:06 PM
