Chrysler Aspen 2007/ Lod shaking
My Chrysler Aspen started shaking at certain speeds, especially on freeway. It stops when I apply the brakes or acclelerate. It also shakes at low speeds. I had 4 new tires put on around 5 mo. ago. I took it to a local mechanic but, of course, the shaking stopped. He ran a diagnostic test and nothing was wrong. I am on disability with a limited income and every time I take my vehicle in to the shop they find a ton of problems and I leave feeling like I have been totally taken advantage of (I am clueless when it comes to automobiles). I just wanted to research the problem before spending a ton of money...Any ideas?
Let us know.
Steve
For starters, if you feel a shop is taking advantage of you, you need to find another shop. Repair shops should make you feel comfortable. Not only in their knowledge on working on your vehicle, but in making sure you understand what they are talking about by explaining in detail or showing you what they talking about. You can also seek advice from a second shop for confirmation of work needed as well as a comparison price.
Secondly, if you have broken a drive shaft & two control arms, you have been doing some serious off road driving. It takes a lot to break a control arm and even more to break a drive shaft. Unless you live in a state that salts roads and they have simply rusted through or the half shafts have not been properly maintained.
A few things you don't mention is what kind of drive line you have. 2WD or 4WD. You also don't specify which control arms (upper or lower) or which drive shaft (front,rear,half) are broken. Perhaps they didn't clarify which were broken. The front and half shafts would only apply if you have 4WD.
However, here are some prices for you for these components. Note these are just quick price look ups on popular Chrysler parts websites and do not include labor.
Upper control arm: $125.00
Lower control arm: $700.00
Half Shafts: $100.00 ** Only on 4WD vehicles **
Front Drive Shaft: $400-$600 ** Only on 4WD vehicles **
Rear Drive Shaft: $400-$500
Hope this helps.
Hope this helps.
Laura,
I completely agree with Calamity Coyote, I was thinking the exact same things and I recommend you going some place else for another opinion. Like CC said, short of some serious off roading, I can't image have all those repairs being necessary.
Please keep us informed.
Steve
Steve
