dies 99 sebring
Old Oct 6, 2010 | 09:50 AM
low-keyseg92's Avatar
Default dies 99 sebring
I have a 99 sebring convertable 4 cyl. The car will start fine and run for about 10 minutes then it dies. The strange thing is that when I turn the key to restart it there is nothing. Like the battery is dead. If I push the gas peddle about half way while turning the key all of a sudden the car cranks. It will keep cranking until I release the gas peddle. If the car is sitting with the key forward the fuse box is clicking and the throttle position sensor is hissing. I unplugged it and the fuse box made a bunch of noise. I have a CEL but no way of getting it somewhere to pull codes. If the car sits for 2 hours it will crank up normally (without pressing the gas). Fuel pump primes,spark is there etc...any clues? Im thinking its the ECU or the throttle position sensor has shorted.
Old Oct 6, 2010 | 11:20 PM
no-one....I did some research and it could be teh crank sensor. I just dont understand why the fuse box would be clicking and why teh car will only crank when the gas pedde is pressed. Ill keep looking.
Old Oct 7, 2010 | 12:51 PM
TNtech's Avatar
Internal short in the Throttle Position Sensor. If any sensor on the 5V circuit does that it will take the PCM BUS down.
Old Oct 8, 2010 | 09:10 AM
thank you TNtech. I was on the right track. I was hoping somone would verify my thoughts. I was looking into it this morning and started unplugging sensors and the shorting stopped when the TPS was unplugged. Perhaps you can tell me if the sensor directly under the TPS is the IACV or something else. I cleaned the throttle plate and sprayed for vacuume leaks while checking the EGR valve. Other than a filthy air filter the car seems ok. BTW this is not my car...I drive a HONDA....lmao thanks again for your help.
Old Oct 9, 2010 | 01:36 PM
TNtech's Avatar
Yeah that's the IAC motor.
Old Oct 11, 2010 | 11:29 PM
Well I changed the TPS and it still died. Im thinking its the IACV because it still did the buzzing and clicking. I figure both might be bad tho. After working on it she told me that she had hit a huge bump and thats whenthis started. The owner of the car dont have the money to fix it anyway so it can sit. Thanks for the help.
RogueInLA
Mar 31, 2014 08:54 AM
Steven60970
Dec 19, 2011 07:04 PM
persian69
Sep 16, 2011 05:32 PM
ccain
Jul 1, 2011 10:10 AM
Duppep24
Aug 25, 2009 05:09 PM
