Drive axle nut size ??
Old Mar 7, 2010 | 03:50 PM
thorze's Avatar
Question Drive axle nut size ??
So I need to replace the wheel bearing on the front pass side of my 96 Sebring Convt. and realizr that I don't have a socket large enough to fit....is it a 33MM does anyone know ??
Thanks for any replies!!
Old Mar 8, 2010 | 09:20 PM
master tech's Avatar
Socket is 1 1/4.
Old Mar 9, 2010 | 09:10 PM
It's probably a metric size equivalent to 1 1/4, which would be closer to 32 mm.
To replace the hub bearing you'll need to disconnect the ball joints and pull the steering knuckle.
Old Oct 19, 2017 | 05:25 PM
Don Clark's Avatar
Default 2011 Chrysler 200 wheel bearing / hub assembly changeout
Originally Posted by master tech
Socket is 1 1/4.
Thanks for the size information. 1 - 1/4 worked flawlessly on my 2011 Chrysler 200.
Old Nov 11, 2023 | 11:01 AM
Lost10mm's Avatar
Default Axle Nut
Both 32mm and 1¼ in. works. On a 2011 200 you don't need to pull the knuckle off to change the bearing hub. It can be done using penetrating oil and a heavy hammer. Take the axle nut off first, then push the shaft back for enough room to get the bolts out.
Chad Forystek
Oct 9, 2014 03:37 PM
ohboyseth09
Apr 9, 2010 11:48 PM
phatboyfromla
Apr 1, 2009 02:40 PM
sumncguy
Dec 7, 2007 10:18 PM
sumncguy
Jul 11, 2007 01:14 PM
