durango heated seats not working
Old 11-10-2005, 06:23 PM
ridingr6's Avatar
Default durango heated seats not working
The heated seats in my durango quit working, they do not warm up, I checked the fuses and the swithes in the console all ok. My question is there a relay some were or they element in the seats bad? Thanks
Old 11-10-2005, 09:00 PM
Default RE: durango heated seats not working
The control switch and timer relay are integrated into a single panel. Does your indicter light come on when you turn the switch to on. Use an ampmeter on the battery, it should read 14 volts approx when you turn the switch on it should read higher. also there is a fusible link . if its melted you still could have short from melting wires fom one of the heating elements. you hve to start some where.
Old 11-10-2005, 10:07 PM
ridingr6's Avatar
The indictor lights for the high and low positions do not light. I was just hoping for an easy fix before I take the seats out . Thanks
Old 01-05-2006, 09:16 PM
i just read your question on your heated seats and i'm quite sure its a problem with the heating grids in the seat cusions (the lower part you sit on). i was a chrysler tech for a long time and changed hundreds of those. what happens is over a period of time from being sat on the heating element wires break resulting in no heat. the elements can be replaced. there are tsb's for this issue but i can't remember the number off hand sorry. you can e-mail me if you have a question.
Old 01-08-2006, 10:27 PM
ridingr6's Avatar
I took hte durango to the local dodge dealer to have the seats checked, they found the seat module needed replaced. They wanted to charge me $320 to fix my wife's bun warmers!!!!!! I told them that I'll think about it. Now were is the seat module located, they would not tell me at the dealership. Please help .
Old 03-01-2006, 07:54 PM
UNDER THE SEAT BLACK BOX
Old 12-18-2008, 12:42 PM
I own a 2003 Dodge Durango SLT Plus with Leather Heated Seats. My driver Side seat is working with no problem, but my passenger side seat is not heating up. When I click the switch to High or Low, the light does come on, but the seat does not heat up. Someone said it may be the element under the seat, but if that is broke, would the light stay on or go off? Any other ideas? How easy is this to change? Anyone have any ideas??
Let me know...Thanks, phil nicotoscani1@yahoo.com
easyryder01
03-11-2018 11:54 AM
pete@co.uk
04-01-2014 08:02 AM
dean46304
06-26-2007 10:17 PM
comports
02-12-2007 06:13 PM
wifes 300m
02-11-2007 01:59 PM
Quick Reply: durango heated seats not working
