Electrical Problem? 1995 New Yorker
Old Jun 27, 2009 | 04:47 AM
Alguien's Avatar
Default Electrical Problem? 1995 New Yorker
Hi
I got another question about my ’95 Chrysler New Yorker. Lately the car seems o give some problems. But I guess they are not major but they unfortunately do exist.
1. When driving the car it seems like at times the engine is hesitant, it feels like something is stopping and then running again – when this occurs power is also not really there, but returns after a short time again. I mean the engine does not run round and smooth. The plugs and wires are fine, this has been checked. When I turn the engine off and restart it seems like the motor runs smooth now without any problems. Some years ago I had a problem when driving all in a sudden nothing electrical would work anymore and the dash board looked like a xmas tree – all lights came on. When I restarted the car it all worked fine again.
2. The a/c also works on and off. Sometimes it comes on quickly at other occasions it takes forever or restarting the motor does the trick. Yesterday I noticed after the washing the car the outside temperature was displayed at about 69 degrees after washing; while the inside was set to 73 degrees. The actual outside temperature was at about 85 degrees. The entire system was confused until the outside temperature was correctly displayed again at 85 degrees after about 5 minutes. I am wondering if cleaning the thermostat for the outside temperature would help that the system runs normally. Can somebody advice where to find the thermostat?
Any advices on these two problems are really appreciated and I already thank in advance.
Kind Regards
Alguien
Old Jun 29, 2009 | 03:48 PM
1. Check the computer for codes.
2. The temperature sensor is usually located behind the front bumper. If it's not reading correctly it could affect the way the A/C operates but if you sprayed it with cold water while washing the car it will react to that.
Old Jul 2, 2009 | 05:00 AM
Alguien's Avatar
Hi dcotter0579
Thanks again for your advice. I will check for the outside thermostate and see if it is dirty.
I noticed before that the outside temperature reading was acting up at times before. But it did reset itself after some minutes. Perhaps a film of dirt is the problem, so many times the Chrysler garage said they had to change the a/c hose for a lot of money to make the a/c work. Funny was that all the hoses still look old, the new one should at least be visible.
What I don't understand is reading the computer codes in 1.? Do you mean to go to Chrysler and have them hook the car up to their computer and check for errors?
Thanks.
Kind Regards
Alguien
rdrodgers
Aug 22, 2013 11:39 AM
Alguien
Jun 25, 2011 08:00 AM
Alguien
Jun 8, 2011 03:52 AM
Jimbob
Oct 26, 2010 02:13 PM
Alguien
Jun 27, 2009 04:48 AM
