Heater Issue - No blower in front
Old Jan 21, 2007 | 01:58 AM
user440's Avatar
Default Heater Issue - No blower in front
04 Chrysler Pacifica AWD with automatic heat plus rear heat.
Suddenly the front blower on my Pacficia seems to have failed. Instrumentation works fine as does the heat in the back; however the blower does not appear to be working for the front heat. Thinking it was the fuse, I check this first of course which turned out fine. When I called the garage to see if they had a relay in stock thinking this might be the issue, he replied that it is likely the blower motor resister. His indication was that these things go out all the time.
There was a similar post here: https://www.chryslerforum.com/m_6827/tm.htm
Does this indeed look like the problem?
How easily replaced are these things?
Thanks,
Mike
Old Jan 21, 2007 | 04:58 AM
Default RE: Heater Issue - No blower in front
yep replace the resistor module because u have auto air
smishoe1
Aug 5, 2013 10:34 AM
copprtop97
Dec 27, 2012 07:01 PM
04pacifica
Mar 6, 2011 09:03 AM
loral
Dec 16, 2008 04:36 PM
kunkeljm
May 20, 2008 02:29 PM
