Mysterious problem with left brake light
Old Feb 18, 2012 | 02:58 PM
jojo42's Avatar
Default Mysterious problem with left brake light
Hi
My Chrysler Neon's left brake light is not working when driving lights are on. Tail light is working correctly but also dims out when brake pedal is pressed. If lights are not on, brake light works properly.
I measured the voltages from the left side socket:
1. Lights on (~8 V). Everything working correctly.
2. Lights out, brake pedal pressed (~13V). Same function as right side which works properly all the time.
3. Lights on, brake pedal pressed (~0.5V). Obviously there is a short circuit, but how in the earth it is possible. In my understanding there are three wires coming to the socket and all are working correctly when operated separately but not together?
Alright, if somebody has any clue what might be the problem please let me know.
Thanks, Joonas
Old Feb 18, 2012 | 03:25 PM
NicKeiRacing's Avatar
1thing to try is to replace the stop and tail light bulb.
If a filament in side the bulb has dropped funny it can cause similar problem.
Let me know how you get on.
Old Feb 18, 2012 | 04:49 PM
TNtech's Avatar
Do you have the wrong bulb in it? Are the filaments touching inside the bulb? Corrosion in the socket?
Old Feb 18, 2012 | 06:46 PM
Bad ground. Can pass current for one filament but cannot pass current for both. Find the ground wire for that side, loosen and re-tighten the screw.
Old Feb 19, 2012 | 04:41 AM
jojo42's Avatar
I think the problem could be with bad wiring to the socket. I can't seem to find any info of the tail light socket and I don't see any screws there. Black wire should be the ground, right?
How can I remove the socket or the wire and reconnect it or should I buy a new socket altogether?
Old Feb 19, 2012 | 04:55 PM
Black wire is the ground. Follow it to the ground point. Shouldn't be too far.
If that doesn't work, get a whole new socket. Try a parts store. If they don't carry it, go to the dealer. You won't break the bank.
Old Feb 20, 2012 | 08:53 AM
jojo42's Avatar
Got it partly figured out. As you said the problem was bad ground and I tested it with a extra wire going from the bulb to ground. I'm going to put some crc to the socket and if that doesn't work, I'll buy a new socket.
Thanks a lot for your help!
Joonas.
Old Feb 20, 2012 | 03:41 PM
If the problem is a bad ground, then replacing the socket won't fix it. You've got to either run a new wire to the socket from a new ground or trace the harness to the old ground and clean the connection there.
ssdavies1
Dec 2, 2014 10:28 AM
rmbb
Sep 1, 2012 05:20 AM
TWillis
Cirrus & Breeze
Jul 13, 2012 02:09 PM
click, click.
Jan 15, 2010 05:49 PM
keyology
Aug 6, 2009 07:39 PM
