Need advice/Motor flush/engine sludge problem
Old May 12, 2008 | 08:13 AM
bacalao's Avatar
Default Need advice/Motor flush/engine sludge problem
Does anyone have any tips on a good way to/ or brand product that will do a good job on flushing engine?
Old May 12, 2008 | 06:58 PM
carbuff2's Avatar
Default RE: Need advice/Motor flush/engine sludge problem
The guys on the BOBISTHEOILGUY.com forums seem to like Auto-RX
http://www.auto-rx.com/
Never needed it myself.
Old May 15, 2008 | 09:51 AM
johno's Avatar
how do you know you have enough sludge to worry about.
if you have a bunch it's from a lack of mtce OR short trips OR maybe even s thermostat issue not working MAYBE not even in there to allow engine to heat up properly. do you get plenty of heat ?
is there collant in the oil ?
If short trips are your issue run it liek 20 miles once per week. it better for the engine oil and keeps exhaust system from rusting out quickly.
I have used 1/2 can of sea Foam. OR1/2 can of most any transfluid run it 15 minutes and change the oil. bothworkwell. I have done both . my neigh bor had a for temp with a 4 cylinder in it and i could not believe the amount so sludge in the valve cover, we scraped a lot off with tools befoe putting valve cover back on and flusing the engine with an old 1/2 quart of tranny oil.
kenzenor
Nov 23, 2014 04:07 PM
zach92
Feb 9, 2014 07:55 AM
dcotter0579
Mar 17, 2011 02:36 PM
wylecoyote
Sep 21, 2010 03:55 PM
bacalao
May 8, 2008 12:16 PM
