Oil Pressure
Old Feb 4, 2008 | 09:32 PM
weinerschizel's Avatar
Default Oil Pressure
There is an issue with oil pressure in my 1999 Chrysler Concorde. When the motor warms up and it's idling the oil pressure light comes on. I have to put it in neutral and kick the revs up to around 1k rpm before it turns off again.
The oil looks good as new and is full. I was going to first replace the oil pressure sensor but I cannot find where it's at on the block. This is a 2.7 L engine. Does anybody know where it's located?
Also I was wondering if the pump is wearing out. I've got not quite 90k miles on the car. But again I cannot find a replacement pump. Where do they sell them and about what do they run?
Any suggestions from people w/ experience would be greatly appreciated. Thanks much.
Old Feb 5, 2008 | 02:25 PM
Default RE: Oil Pressure
I did this on my 99 Condorde with a 2.7
NO: 08-36-99 SUBJECT: Engine Oil Pressure Light Flicker DATE: Oct. 15, 1999 OVERVIEW: This bulletin involves adding a terminal/wire/vent to the oil pressure switch connector. NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 2.7L ENGINE. SYMPTOM/CONDITION: With a hot engine the oil pressure light may be on or flicker on at idle. DIAGNOSIS: Verify engine oil pressure as described on page 9-21 of the 1999 Concorde/Intrepid/LHS/300M service manual (Publication No. 81-270-9140). If engine oil pressure is within specification perform the Repair Procedure. PARTS REQUIRED: Qty Part No. Description 1 05017800AA Wire Terminal/Vent REPAIR PROCEDURE: [ol][*]Raise vehicle on a suitable hoist.[*]Remove engine oil pressure switch connector from switch.[*]Remove sealing dart from the empty cavity at the rear of the connector.[*]Pull terminal locking ring outward from front (switch) side of connector to gain access to terminal locking tabs.[*]Install wire terminal/vent, p/n 05017800AA, in place of the removed sealing dart. Slide locking ring back into place.[*]Attach the connector back on the oil pressure switch.[*]Spot tape the wire/vent to follow the harness towards the top of the engine compartment[/ol]
the pressure switch is on the pass side block
Old Feb 6, 2008 | 12:01 PM
moe's Avatar
moe
damn,tech i havent seen that repair in a long time.butit still works on single wire switches.
Old Feb 6, 2008 | 03:09 PM
yeah I know it they still put the dam little plug in there to
billbon8
23
Jul 18, 2011 04:48 PM
gbwiii
Jan 6, 2009 03:48 AM
markr
Apr 17, 2007 09:13 PM
vettman
Aug 15, 2006 11:20 AM
ohare
Aug 14, 2006 10:23 PM
