Roof rack installation problem
Old Jun 23, 2007 | 01:30 PM
ettienne's Avatar
Default Roof rack installation problem
I'm trying to install a Mopar roof rack on a 2002 Chrysler Voyager SWB.
My problem is with the expansion nuts, I cannot get them to expand.
I used the method illustrated in the installation instructions: use a bolt, nut and washer to expand the expansion nuts. My problem is that the expansion nuts turn in the hole in the roof when I tighten the nut, so the expansion nut does not compress.
What is the trick behind getting the nut to expand?
Old Jun 23, 2007 | 04:36 PM
ettienne's Avatar
Default RE: Roof rack installation problem
I applied some lateral thinking and came up with a solution.
I cut the head off a 7mm bolt, filed away some thread so I had a smooth shaft to fit in my pop riveter, screwed the nuts onto the remaining thread and pop riveted them in.
dwstucke
May 28, 2019 08:30 AM
thehappygiant
Jan 18, 2009 11:23 AM
ssstw1
Feb 10, 2008 03:49 PM
VFRbeliever
Dec 18, 2007 03:29 PM
Ronspacifica
Feb 15, 2007 03:35 AM
