Temperature gauge with warning light?
Old Aug 1, 2013 | 11:07 PM
Pazilla's Avatar
Default Temperature gauge with warning light?
Cant find temp warning light near temp gauge, should there be one? After putting ignition on looks like all warning are working, exept temp warning. It might be a blown bulb? What happens when temp rises too much.. a sound warning(beep..?) Car is '96 Neon.
Old Aug 2, 2013 | 08:34 AM
Your owners manual should describe all the lights and gauges of the instrument panel.
Old Aug 16, 2013 | 07:25 AM
anddrival's Avatar
Thanks for sharing about this problem. This thread is really important in this regard and very helpful to fix this issue.
Old Aug 16, 2013 | 08:36 AM
Pazilla's Avatar
For me this was a big issue, never had a car with no temp warning light...
and temp gauge was always showing max. 2/5, when really hot too and fan on, so i didnt trust it at all... broken gauge or temp sensor or bad welding on circuit board?
But i got an answer from Finnish chrysler website and i want to share this with you all:
-Detach coolant temp sensor connector
-Turn ignition on, temp gauge should be at lowest position
- Ground temp gauge sending unit connector pin 3.Turn ignition on, temp gauge should be at highest position and you should hear a warning sound.
- If OK, check temp sending unit connection,if OK renew sending unit.
- If not OK, with sound and gauge showing Cold, renew gauge. If this is not helping you should check instrument panel circuit board.
I got bad sending unit or bad connection. I changed the unit.
bgeise
Sep 12, 2014 10:38 AM
UniversalShaman
May 16, 2014 03:01 PM
OddJack
Jan 28, 2011 05:48 AM
Randy Merrill
Nov 13, 2010 10:22 PM
black71gp
Apr 23, 2008 08:07 PM
