Transmission oil pan GASKET question
Old Feb 28, 2009 | 10:54 PM
MauriS69's Avatar
Talking Transmission oil pan GASKET question
Does a transmission oil pan gasket need silicone gasket maker? (such as Permatex Ultra Black or Permatex Blue RTV silicone gasket makers)
The gasket is made out of rubber, and it came with the tranmission filter I'll be replacing.
This is for a 95 Chrysler LHS, 3.5L, 148K miles.
Thanks for your help
Old Mar 2, 2009 | 08:47 PM
Yes. Go with the black.
Old Mar 16, 2009 | 05:50 PM
moe7404's Avatar
Default not rtv
fel pro will NOT warrenty a valvecover gasket if it has rtv on it.
i like permatex #2. its never failed me in 40 odd years. rtv has silocone thats lets the gasket move around.
Old Mar 17, 2009 | 03:03 PM
Rick99's Avatar
I used the rubber gasket that came with the filter I bought at CarQuest-- I put it on dry and have had no problems with it.
Old Mar 17, 2009 | 10:31 PM
Pacifica3.82007's Avatar
I like to use a thin coating of Permatex Gasket Sealer/Conditioner. It's a thick gray subtance that not only holds the gasket in place while you put the pan back, but it keeps the original Chrysler gasket from drying out and failing. Good stuff, it never hardens and you can always re-use the gasket.
http://www.permatex.com/products/Aut...t_Dressing.htm
ollerich29
Oct 20, 2012 08:56 PM
JoeF2002
Dec 2, 2010 10:07 AM
Termite
Sep 15, 2009 10:03 PM
02sebringCT
Nov 22, 2007 12:39 PM
dennine3003
Feb 24, 2006 07:50 AM
