Trunk light switch?
Old Jan 16, 2010 | 12:15 AM
leeb's Avatar
Default Trunk light switch?
Can anyone tell me where the trunk light switch is on a 97 Sebring coupe?
As far as I can tell, all the fuses are good, the bulb is new, but the light does not come on.... period.
Sometimes it would be nice to see what I'm looking for!
My book is more-than-useless in tracking down something they seem to forget is there.
ANY/all help would be appreciated!
Old Jan 16, 2010 | 11:04 AM
It's probably built into the release mechanism in the latch. On the sedan/convertible, it activates the "deck" signal in the odometer readout when the trunk is not latched. Not sure about the Coupe but one would think it might be similar.
Old Jan 17, 2010 | 02:37 AM
leeb's Avatar
Dont know that Ive ever seen a 'deck' light... will check my book/owners manual 2c if it shows anything...
Admittedly, I cant remember ever leaving the trunk open w/ the switch on...
Thanks for the input!
Old Jan 18, 2010 | 02:54 AM
leeb's Avatar
The owners manual does not show a reference to a deck light in the panel...
Anyone else see this 'problem'?
Old Apr 26, 2013 | 01:00 PM
sdeal5's Avatar
Question
i too am haven this issue, has any one found a fix for this issue yet??
Old Apr 28, 2013 | 03:14 PM
If you have access to a Haynes manual, look on page 12-56. There's a wiring diagram there that shows the trunk light being controlled by a switch called "trunk lid latch switch" making me believe it's built into the latch as stated above. Power is on the same line as The rear interior "personal lights" and the switch in the latch controls the ground. So if your rear interior "personal" lights work, try jumpng the pink wire from the trunk light to ground. If that turns the light on, then you know the problem is between the light and ground, which includes the switch in the latch.
Page 12-55 shows the system for earlier coupe modes. It's similar in principle but the wire to check is red/green, not pink.
Old Apr 29, 2013 | 11:38 AM
sdeal5's Avatar
Cool
ok kool im gonna start trouble shooting it asap.. wish me luck.. i would really like to get this fixed soon...
Old Apr 29, 2013 | 02:37 PM
sdeal5's Avatar
ok so i just tested all wiring that had to do with my trunk light and there power going to that light bulb, so im stumped... i thinck i might have to replace the latch.. what do u guys think??? is there any other solution???
Old Apr 29, 2013 | 05:07 PM
Try taking out the latch and testing it. If it's good, then the problem is with the ground. If the latch switch is bad, you'll need to fix it or replace it. Finding the replacement part could be a challenge.
You're sure the bulb is good, right?
Old Apr 29, 2013 | 05:46 PM
sdeal5's Avatar
yes the bulb is good, just got a new one from autozone... where on the latch is the ground located??? i seen 3 prongs on the trunk latch only 2 of witch have wires attached to them... is this correct???
