turn signal on a pacifica 04
turn signal on back passenger side dont work when headlights are on works fine when headlights are off when i hit the turn signal when the headlights are on the fog lamps i think thats what they are comes on and the turn signal flasher goes fast
Check the ground wire to that light. Trace the black wire to where it connects to the frame. Loosen the screw holding it a little and wiggle the connector to break up any corrosion, then re-tighten the screw. That should do it.
swittie
Nov 10, 2020 02:02 PM
GSKI
13
Sep 11, 2007 09:33 AM
