K-Cars Talk about the infamous K-Cars within.
1993 ny headlight covers
Old Sep 10, 2015 | 07:14 PM
N.Numchuck's Avatar
Default 1993 ny headlight covers
Went out to start my NY the other day and battery was dead. Charged battery and got started. When I turned it off noticed battery voltage was dropping quick. so disconnected battery and found a 4-5 amp drain. So as I was hooking battery back up notice the headlight doors were open even though the lights were turned off. Also notice a clicking with the headlight door relays. so I pulled the 2 headlight door relays, checked amperage drain and it was .2-.4 amp which was reasonable. So i checked the relays and the coils checked out to 82 ohms. all contacts checked out OK. but according to the chrysler schematic there should have been a built in diode with the relay so one direction would be 0 ohms and the other the coil ohmage of 82 ohms. I got 82 ohms both directions. so I unplugged the motor and hooked up 12 v and it would close the doors, switched the polarity and they would close. so motor checks out good. what usually causes the headlight doors to goo wacky? is it the light switch you pull out to turn on the headlights or maybe the body computer? Also didn't see alimit switch that tell the headlight doors to stop. Is that controlled by the body computer? Anybody have any experience with fixing this? What part usually goes bad?
Thanks for any help.
Old Sep 12, 2015 | 12:59 PM
N.Numchuck's Avatar
Now my trunk keeps popping open all the time. Me thinks the body computer went south!! Does anyone know if body computers are interchangable? New Yorker-Imperial 1990-1993?
Anyone ever had to replace it?
Old Oct 12, 2015 | 05:27 PM
marty mopar's Avatar
Relays 1993 C body
4728 990 1 Starter
B 5252 672 1 Horn
C 5252 672 1 Headlamp Delay
D 5234 471 1 A/C Clutch Cutout W.O.T.
E 5234 471 1 C-Y Radiator Fan (Use Insul. 4439085)
F 5234 471 1 C-Y Fuel Pump
G 5234 471 1 C-Y Auto Shutdown
H 5252 672 1 C-Y Concealed Headlamp & Door Lock & H/Lp. Delay
I Electronic Transmission
J 5266 187 1 C-Y Anti-Lock Brake (Pump Motor)
5252 672 1 C-Y Anti-Lock Brake, (Modulator)
K 5234 471 1 C-Y Back-Up Lamp
5234 471 1 C-Y E.A.T.X., w/Brkt.
5256 025 1 C-Y Sunroof Control
5252 672 1 C-Y Twilight Sentinel
5252 672 C-Y Park Lamp
4373 307 1 C-Y Load Leveler
4687 588 1 C-Y Load Leveler, w/Bracket
5252 672 1 Door Lock
3600 3031 1 Pwr. Antenna & Speaker
5252672 is it 4373229 is cast on the part I have these NOS
Arizona Parts - NOS Mopar Parts
SARG
May 10, 2008 05:49 PM
trinisebring
Jul 22, 2007 08:39 PM
TSomers
Aug 21, 2006 02:41 PM
Apr 10, 2006 05:59 AM
Racinfan83
Dec 10, 2005 11:50 PM
