2001 SEBRING conv no spark
Old Dec 26, 2015 | 07:04 PM
LEOPARD's Avatar
Question 2001 SEBRING conv no spark
Hi I own two 2001 conv just bought 2nd one and pulled motor and put in one from wrecker now I have no spark my other one needs water pump but runs so I borrowed crank and cam sensor from it ,still no spark ....any suggestions ...I'm a Chrysler rookie but wrenched on personal vechiles my whole life trained marine mechanic but this newr ****e baffles me sometimes??why on earth didn't Chrysler just stick with internal combustion ??why add internal waterpump ,guess I'll never know!!!
Old Dec 26, 2015 | 07:07 PM
LEOPARD's Avatar
I did break crank sensor on engine INSTALL goin out to car now to check harness,,maybe I should just swap harness with other one and see what happens ,,also do a alarm reset cuz battery went dead ,any more suggestions
Old Dec 28, 2015 | 07:26 PM
what engine did u install? what year?
Old Dec 29, 2015 | 04:54 PM
LEOPARD's Avatar
I believe it was outta a 2002 I have spark now...zero compression now on all 6..is it possible to bend a valve in all cylinders turning engine over by hand and by starter??damm ...
Old Dec 29, 2015 | 04:57 PM
LEOPARD's Avatar
Thanx Kevin ...also I didn't have a puller for harmonic but upper marks lined up..so I thought bottom was OK..I measyred distance from piston top to head on other block and rotated that one to same and links matched marks...and finished assembly
Old Dec 30, 2015 | 12:02 AM
if you have no compression yeah bent vales
Old Dec 31, 2015 | 04:49 PM
LEOPARD's Avatar
Would it bend one or more valves per cylinder just by cranking over by hand and with starter??thanks for your replies I do appreciate your input thanx mark
Old Jan 1, 2016 | 10:01 AM
yeah either one it will
Old Jan 1, 2016 | 01:27 PM
LEOPARD's Avatar
Ohh man ..thanx again ...soo I have a spare engine I guess I could just swap heads??what do u think ?cams and all??just reset chaain and hope for the best??that seems my cheapest fix (my time)
Old Jan 1, 2016 | 01:28 PM
LEOPARD's Avatar
Or pop valves out and replace bent ones ..so u say they All could possibly be bent??
