2002 T/C alternator issue
Old Jan 2, 2015 | 11:06 PM
thrandall's Avatar
Default 2002 T/C alternator issue
I have been trying for 2 days to unclip the connector on my alternator for 2 days now. can't figure it out. Removing the bolts was no problem. Pepboys and the dealer are not willing to share any info. Some say squeeze the bottom, some have said put a screwdriver in it. At a loss...frustrated.
Old Jan 3, 2015 | 10:15 AM
did u pull back the little red clip first?
Old Jan 3, 2015 | 11:21 AM
thrandall's Avatar
Default clip
there is no little red clip
Old Jan 3, 2015 | 12:57 PM
thrandall's Avatar
KKeller608@aol.com, I turned it over and there is a red clip on the bottom of the connector. it is damaged now for 2 days of trying to push it in with a screwdriver (advice from pepboys)....I assume that with a small screwdriver or needle nose I should be able to pull the red tag (whats left of it out) and thereby be able to separated the connector.
Old Jan 3, 2015 | 11:03 PM
correct use a pick that will work better
Old Jan 5, 2015 | 02:13 PM
thrandall's Avatar
Well, finally got it off. Broke the connector in the process (the end on the harness. Put it all together in about 20 minutes, using electrical tape to secure the connector until I can either buy a new harness (not looking forward to changing that) or slicing a new or used connector on old harness.
Old Jan 6, 2015 | 01:53 AM
get a used connector easy to find clip off old one with as much wire as u can get then u can splice in that connector to your harness easy enough
brewman
Oct 2, 2013 02:36 AM
Constant
Oct 30, 2011 11:48 PM
kyo001
Oct 15, 2010 02:13 PM
kyo001
Oct 11, 2010 06:42 PM
fdfever
Feb 10, 2008 10:14 AM
