2004 Chrysler sebring charging issues
Old Nov 29, 2016 | 06:22 PM
mechaniker1986's Avatar
Loss of voltage from the alternator to the battery probably means a bad connection somewhere in the circuit. By "bad" I mean corroded or loose. Fusible links either pass current or not. There is no in-between. Dirty connections have electrical resistance and there is a resultant loss of voltage.
If the battery is showing only 9 volts, it's bad.
I feel like this will only make things worse. I jumped the car again today and removed the cables. With the car running I did a voltage test on the alternator and it was below 14v at a steady decline. I feel like a nimrod. The first tome I did the voltage test on the alternator, it was reading 14+ volts and now it's not. I have now turned my attention to either the alternator being bad or a loose connection somewhere causing it not to put out necessary voltage. Would the battery cause this? I apologize if my confusion going back and forth is causing a headache. It is for me.
Old Dec 1, 2016 | 01:47 PM
ok simple basic things. A battery is only used when starting a car thats all the alternator takes over and is running the voltages needed to do everything. SO HAVING TO JUMP START A CAR EVERY MORNING LEAVES ONE CONCLUSION. THE BATTERY IS WEAK GET A NEW ONE.
Eddo22
Jan 24, 2017 04:07 PM
nana3
Sep 23, 2015 02:22 PM
blkdout_tsi
Jan 25, 2014 10:16 AM
msg123456
Jan 24, 2011 10:20 PM
