Chrysler sebring problems
Old Oct 24, 2022 | 05:43 PM
Toshiba1975's Avatar
Default Chrysler sebring problems
Have 06 Chrysler sebring and my battery light is coming on while i drive. Alternator is fairly new. Battery is new. Not sure what the problem could be. Need help. Local mechanic who knows what he is doing. Mpls
Old Oct 25, 2022 | 09:47 AM
ggoose's Avatar
Is the battery lamp on when you first start the engine or does it come on after driving a bit? Does it turn on/off while driving or once on it stays on?
The battery lamp typically notes an issue with the charging system. If the lamp is on there should be a dtc (diagnostic trouble code) set. A good hand-held scanner would be able to pull the code(s).
What is the engine running voltage? Should be 14.2 volts to 14.4 volts give or take. Is the alternator new or a rebuild? I have had rebuilds fail in under a year.
americandxer
Aug 27, 2021 05:04 PM
nickstoyz
Jun 2, 2016 02:55 PM
blkdout_tsi
Jan 25, 2014 10:16 AM
ikimow
Sep 30, 2008 06:05 PM
EvilZombieZ
Dec 21, 2006 11:32 PM
