Other Any other Chrysler within.
Audio help?
Old Aug 17, 2006 | 07:25 PM
1988chrysler5thave's Avatar
Default Audio help?
I have a 1988 Chrysler 5th Avenue that I want to install a after market stereo, but I have hit a rather small wall. I have the install kit, but when I was searching for the wire harness I found 2 things that kind of confused me a bit. I found this which they are saying is required for my car http://www.discountcarstereo.com/detail.aspx?ID=274
Now here is where the confusion comes in, I have also found this http://www.installer.com/item/displa...php?it=71-1817
So which one do i need?
Also does anyone know where I can find a diagram on how to remove the dash?
Old Feb 13, 2007 | 11:52 PM
jonnymagnum's Avatar
Default RE: Audio help?
if you have the sound system that has the built in amp. (you will havea push in button on the botton of the dash by the ash tray) then you need the one posted in the 1st link.
If you have the base sound system then you need the one posted in the second link.
and as far as the dash piece comming off. its jut screwed on. I forget how many, but just look arund and you'll find them. and it's will pull out easier if the gear shifter is put down to the bottom in 1st gear.
asterix4real
Nov 17, 2014 07:16 PM
Bigboi8495
Mar 14, 2009 08:38 PM
tpieples
Jan 19, 2008 01:52 AM
Gregory
Aug 13, 2007 09:46 AM
1988chrysler5thave
Mar 19, 2007 07:52 PM
