Audio help needed
Old Aug 17, 2006 | 07:44 PM
1988chrysler5thave's Avatar
Default Audio help needed
I'm not sure where to post this so I posted here and Other models.
I have a 1988 Chrysler 5th Avenue that I want to install a after market stereo, but I have hit a rather small wall. I have the install kit, but when I was searching for the wire harness I found 2 things that kind of confused me a bit. I found this which they are saying is required for my car http://www.discountcarstereo.com/detail.aspx?ID=274
Now here is where the confusion comes in, I have also found this http://www.installer.com/item/displa...php?it=71-1817
So which one do i need?
Also does anyone know where I can find a diagram on how to remove the dash?
Old Sep 28, 2006 | 06:28 PM
primetime's Avatar
Default RE: Audio help needed
I would definately get the Adapter unit...the first one.
The other one would require you to splice into the existing wiring.......that's a no_no
Old Mar 19, 2007 | 07:52 PM
silver01v6's Avatar
^^^^^agreed^^^^^^ You dont want to cut up your factory wiring. whenever possible use adapters that just plugs into stock, its alot easier to hook up, and later on if you remove it alot easier to undo.
asterix4real
Nov 17, 2014 07:16 PM
Bigboi8495
Mar 14, 2009 08:38 PM
tpieples
Jan 19, 2008 01:52 AM
Gregory
Aug 13, 2007 09:46 AM
1988chrysler5thave
Other
Feb 13, 2007 11:52 PM
