94 LHS Electrical problem
Old Mar 10, 2008 | 10:50 PM
tdcrash63's Avatar
Default 94 LHS Electrical problem
1994 Chrysler LHS Fuel guage is does not work reads quarter ofa tank. Coolant temp reads slightly above C and also does not work, Speedois froze at7mph and also does not work. Tach works but is not accurate reads 3000 when engine is actually turning 2000. All of the idiot lights come on during initial power up. No active engine or transmission codes. Engine runs fine, transmission will shift into all gears going down the road. The info center above the windshield reads calculated fuel milage and trip meter and odometer work.Have pulled Dash cluster. I have power on my ignition feed and battery wires. My grounds ohm out ok 5ohms It appears that this cluster is feed from two wires coming from the body controller? All the wiring I can see behind the dash appears ok Do not no where to go from this point. Any body have any ideas. [align=right][/align]
jclhs850
Feb 19, 2014 02:42 PM
train31
Jun 30, 2008 09:31 AM
tdcrash63
Mar 11, 2008 08:27 PM
mailmule
Dec 15, 2006 03:33 PM
mailmule
Dec 7, 2006 07:04 PM
