3.2L head gasket job
Old Sep 13, 2011 | 09:01 AM
TNtech's Avatar
Originally Posted by titanium
TNtech
You are right. It is the 2.7 in my car. This engine has the water pump inside of the engine. Sorry, my bad.
Putting that thing in there was the worst idea ever. The weep hole system usually works but if it has a major bearing failure it takes down the timing system and dumps AF in the crankcase....wow. Sucky..
Old Sep 17, 2011 | 08:14 AM
Drocky's Avatar
Hey Ponch, sorry I didn't get back to you on the cost. Looks like yours could be different since it's the 2.7. As for the cam lock tools, I ordered them on line from Miller Tools. They were $32 for a set of two. However, I ended up getting the heads decked and completely cleaned out because I had two exhaust valves that had becomne slightly bent and exhaust was coming up on top of the head. Came back looking like new. They are still useful when trying to set the timing because you basically have to get the cam in the right spot for the tool to fit. Just make sure you don't forget to pull them off and put the cam thrust plates back on. As for the cost, here you go:
Head Gasket set from Advance auto parts - $155
Timing Belt from Advance auto parts - $45
Timing Belt pulley from Advance Auto - $31
Water Pump - $52
Cam Lock Tool from Miller Tools - $32
Cam Shaft Bolt from Chrysler - $19
Heads reworked - $535
Wrench 1 7/16 to hold Cam Shaft Sprocket when removing bolt - $13
Had to replace power steering pump because after sitting up for a few weeks, it made all kinds of noise once I got the car running again (probably going bad and after sitting up, the bearing froze up) Advance Auto parts - $46
Also bought new plugs, oil, radiator flush to clean out system, and new power steering fluid.
David
Laimon
Jan 10, 2018 10:56 AM
mikespassi
Nov 21, 2014 11:16 AM
mikespassi
Nov 21, 2014 11:15 AM
mhskog
Jun 9, 2013 01:22 PM
edgrmndz
Sep 2, 2010 02:03 AM
