94 concorde
Old 08-08-2014, 09:27 PM
tx1drvr's Avatar
Post 94 concorde
no power to fuse # 17, no wipers dome lights no ATC no gauges, Air bag light stays on. checked fuse box under hood and all fuses and relays have power to them. 12+ volts no alarm light in the top of dash. car still starts and runs like normal just the above mentioned. any suggestions, thanks.
Old 08-09-2014, 04:33 AM
Ignition switch
Old 08-09-2014, 12:39 PM
tx1drvr's Avatar
ok just curious when i turn key to first position some of the idiot lights come on and then when i finish turning to the on position then the rest of idiot light come on
Old 08-10-2014, 12:13 AM
yep it will do that
Old 08-18-2014, 07:48 PM
tx1drvr's Avatar
Just to let you know it was not the ignition switch. It was the body control module. thanks for your help though.
Old 08-19-2014, 12:59 AM
the BCM has nothing to do with a no power to fuse 17. Did u do the work yourself or have some one else do it?
Old 08-19-2014, 04:44 AM
tx1drvr's Avatar
Had the work done at the local dealer.
Old 08-19-2014, 06:04 PM
so you got charged for a bcm and an ignition switch then correct?
Old 08-20-2014, 10:09 PM
tx1drvr's Avatar
No, they did the troubleshooting and informed me that the bcm was bad. They also informed me that it was no longer avaible through chrylser. I went online and found one and installed it myself and it solved the problem. The key switch is still the one from the factory install.
roughidle
02-07-2013 10:21 PM
Quick Reply: 94 concorde
