Idle speed change after hwy run
Old 04-25-2016, 08:25 AM
teisco's Avatar
Default Idle speed change after hwy run
Just got a used 04 Sebring touring convert a week ago and it has been running perfectly. I took it out on the hwy for a run to see how it handles high speed and it tracked straight and felt solid at 65.
When I got back and pulled into the parking lot it stalled. It did start up right away so I drove it around a bit more and found that my rock steady idle of around 1100 was now fluctuating between 1000 and 500 and running a bit rough.
What could have happened to make this change in idle speed and making it run rougher?
Old 04-25-2016, 01:33 PM
jopizz's Avatar
An idle of 1100 when cold is fine but it should be idling around 600 in drive when warmed up. It should be slightly higher when the A/C is on but not 1100. It's possible your IAC valve is malfunctioning. It may have some carbon buildup. It can be removed and cleaned with some carburetor cleaner.
John
70 roadrunner
12-03-2014 07:48 AM
10Miler
03-22-2013 06:13 AM
bdj5773
08-20-2012 11:38 AM
gbwiii
01-06-2009 03:48 AM
jaydub54
09-11-2008 06:32 PM
Quick Reply: Idle speed change after hwy run
