No HEat
No HEat
I have a 2001 Sebring Convertible. Mostly few problems but for reasons no apparent to me the heat is not working. I turn the **** all the way to the right (full heat) and nothing but cold air.
Any help appreciated
Could be a couple things. If your coolant level is low, you may not be getting heat. Check that first. If it's low, you need to find out why. A leak somewhere?
Could be a plugged heater core.
Could be a faulty blend door in the heater.
Could be a faulty control head.
Are there any other symptoms? Like it blows from the defroster duct rather than anywhere else?
If yours is a 2.7L then that thing on the top of the engine is not the thermostat housing, but rather is called the coolant outlet manifold. There are four bolts holding it in place, three are easy to get out. Browse around the forum to find some threads on the subject.
davet
12-19-2007 04:18 PM
stunod2002
12-15-2006 03:27 PM
